Author Topic: MB 3.3.7454 P: Lyrics not found and not detected if existent in file (Solved)  (Read 1730 times)
Adson
I have noticed that lyrics often are not found although available for a specific track.
Only after a "redo search" they do appear in the lyrics box.
Then I found that the lyrics are also sometimes not detected by MB so that a track WITH lyrics is listed as having NO lyrics.
Screenshot:
https://www.directupload.net/file/d/5834/dul7oz2a_jpg.htm
Maybe something is wrong in my MB settings oder I do something wrong.
But maybe it's a bug that can be eliminated.
Thanks in advance for any help.
Last Edit: June 02, 2020, 12:05:09 PM by Adson
if you are saying that MB is not detecting lyrics that you know are in the file then can you send me a link to a zip of the file so I can see what is going on
FWIW, I had an issue once with a mp3 that although tagged with lyrics would show them sometimes in the lyrics panel, sometimes only in the Edit view, or not at all.  Ran it through MP3val which showed it as corrupted ("garbage at the end of file").  After allowing that app to "fix" the file, then deleting/re-tagging the lyrics (which I had tried before the fix), never had the problem again.
Adson
@frankz: Thanks for fixing the screenshot issue.
I have checked the MP3 with MP3val but it found no problems.
@Steven: Have sent you a PM with a link to the file.
Thanks for your help.  :)
There are no lyrics in the file you sent. I also checked with mp3Tag and foobar
Adson
Steven, thank you very much for your help.
I found that the lyrics that are shown in the lyrics box were downloaded but not saved into the file.
So the track could not be marked as having lyrics.
In the past saving lyrics into the file happend automatically but maybe I have changed that accidentally.
So it was my mistake. Sorry for that  :(
