Author Topic: custom coluumn data missing  (Read 1009 times)
Dpmusicbee
i remove all individual folders that my mp3s were in and just added them back onto the hd. i rescan that drive in mb and all data that were in my custom fields are missing. can someone explain to me why this happen please. i wouldn't think by removing from a folder and then just adding back onto a hd would cause this. side note the missing data show up in mp3tag.
Thanks
Dbee
You probably had the custom tags saved to MB's database and not as a tag within the file. You can chose how you want that handled when you're setting up the custom tag(s).
Dpmusicbee
ok what should i set them to under the save to music file as tag?
Preferences > Tags (1) > custom tags >
Use whichever tag you wish.
Choose a tag that you're no likely to use in the futuer. I've used copyright, publisher, commercial info.
Dpmusicbee
i found that but i don't know what all tracks i have under save music as in the column at the right. right bow i have it set to original filename for all custom columns.
