Author Topic: help me. Please tell me how to change the icon.  (Read 2653 times)
HiGuRaShi
First of all, I'm not good at English so it can be strange
I want you to forgive it.
I used Groove music, but I changed it because MusicBee was recommended.
However, when I changed it, it looked like the one on the right.
I want to set this icon for the artwork registered for each song, but I don't know how to set it.
The picture on the left is an example. (Don't worry about shortcuts)
Those who understand I would love to hear from you.
If it is not possible for each song, please teach me how to change the bee icon.
There was something like changing the icon in the settings, but when I tried it, it did not work.
Is it a tapir?
Thank you.
Tybot
Assuming you're using Windows 10 and that I understand your request correctly, try following this guide:
https://windowsreport.com/thumbnail-previews-not-showing/
If that does not work, this should:
https://www.videohelp.com/software/Media-Preview
Install it and reboot your computer. It says it's for video files but I used it a couple of weeks ago and it displayed the embedded artwork for music files as well.
HiGuRaShi
Thank You!
The icon has been repaired!
How can I change the icon in this image?
MusicBee lets you select the icon through the General/"Select Icon" dialog below.  If you want more than the 4 choices in the "stock" version, you could make your own icons using one of the many free icon creators/editors you can find on the web, and add them to the same folder.  Never did that myself but it should allow you to select such a custom-made icon.
HiGuRaShi
Thank you for your reply
I tried setting it like the picture above, but it was not reflected.
Is this a bug?
