Author Topic: volume louder and softer  (Read 1254 times)
Henry70
Hello,
the volume plays louder and softer. How can I equalize the volume of all my music in MB? Sorry I don't understand what settings I need to be in. Maybe analyze volume?
Yes, you need to run volume analysis on all of your tracks (this will not alter your music, it writes a tag to the music file with the volume information) and then go to the Controls menu and set Smart Gain / Track Gain Only / Album Gain Only as appropriate to your situation.
Henry70
thanks, but smart gain is already set. Do I have to go to volume analysis tools? some tracks are not checked there, I find this strange.
The ones in the tool that are unchecked already have volume analysis information.
Henry70
Frankz, thank you very much for your clear explanation :)
