Author Topic: custom coluumn data removal  (Read 731 times)
Dpmusicbee
have i a custom column called release date. i like to remove a date from there but everything i have tried doesn't remove the date 5/16. can someone tell me how i can remove it please, deleting the entry doesn't work.
Thanks
Dbee
I assume you're trying to remove one date from one file, correct? The "custom" column is populated by a custom tag, which you created, right? Find the track(s) that have the date you want removed, and using the Tag Editor delete the tag. If my assumption is not correct, perhaps some more information about this column and a screenshot would be helpful.
Dpmusicbee
Glad that you got it resolved. Thanks for letting us know.
