Author Topic: Cancel Stereo ENhancer DSP  (Read 1047 times)
Herb_N
I turned on the Stereo Enhancer in DSP to try it out.  I have decided I don't want it. But when I try to remove the check mark, a slider comes up which goes from low to high. But how do I just unselect or cancel Stereo Enhancer altogether?
Are you sure you are just making a single click right in the box itself?  Double-clicking on the entry will just bring up the slider.
Herb_N
Got it. The check box was sticky with my mouse, but your tip caused me to click on the item and then use the space bar to deselect it. Worked fine. Thanks.
