Author Topic: Auto Split Artists  (Read 1668 times)
Daiman2020
As of now and what i could find, when you select a track and open the tag, click on ... next to Artists then split them "changing , to ;"
But i could not find a way to do it when select multi tracks or at import level.
Would any one help please :)
Thanks
If you're just trying to change "," to ";" then you can use the search and replace feature in the Tools menu.
If it's more than that, the Additional Tagging and Reporting Tools plugin can probably help.
Daiman2020
You made me really laugh hard and so amazed ???  :-* , this app has really much options, settings and tools, i did not notice this one you have mentioned, i was looking in the Preferences. a plugin would be ok as well for auto rename at importing music files to MB.
Thanks alot psychoadept
This MusicBee is the best
