Author Topic: Option for Case-Sensitive Searches  (Read 1108 times)
I could make great use of case-sensitive searches when doing a custom search. Not for the the search box on the tool bar, but for custom searches.
I envision in the custom search criteria window a check box to enable/disable the search as case-sensitive or not.
Thanks.
Bumping this in the hope that it might be included in 3.4.
Thanks.
you can already do it using regex. If you search the forum i recall you already raised this issue and i think redwing answered it with how to do it
Ahhh yes, you are correct. My brain cells are suffering from self-isolation.
Thanks.
