Author Topic: ScrobblerBrainz: a plug-in to scrobble tracks to ListenBrainz  (Read 39140 times)
Fabland
Bonjour,
j'ai installé votre plug in, mais rien ne se synchronise.
J'ai reset le jeton, mais malgres tout rien..
Auriez vous une idée.
Merci
Hello
I've installed your plug-in, but nothing syncs.
I reset the token, but still nothing.
Do you have an idea?
Thanks
karaluh
When you open the settings, is your LB user token saved or is the field empty?
ListenBrainz plugin for MusicBee:
https://github.com/karaluh/ScrobblerBrainz
ChuChu
When I listen to a track offline, a JSON file is created in AppData/Roaming/MusicBee/ScrobblerBrainz/Scrobbles, but the scrobble is never added to ListenBrainz after I connect to the internet. I have to manually add it myself. Is this how it is supposed to work?
karaluh
Offline scrobbles are re-submitted only on startup. Restart MusicBee after connecting to the internet and all the offline scrobbles should be automatically submitted.
Gens
Hi, thank you so much for your work!
Sorry to bump, I was wondering if there is any way to have the plugin point to a custom server endpoint if needed? I have achieved this with a few other scrobblers on Android/Linux, but it appears that with MusicBee I'm out of luck, so this is my last hope. I am self-hosting a Maloja instance locally which uses the listenbrainz api to scrobble.
Thanks again!
jan_axhell
Thanks again!
I would like this as well, I use both Navidrome and Musicbee on the same library, but while I can scrobble to Maloja with ND, I cannot with MB, so I have two independent scrobble histories on Maloja and Listenbrainz.fm.
karaluh
OK, fine, I'll look into this  :) If it's as easy as providing custom URL for the scrobble server this should be relatively easy to implement.
Havokdan
The version that came out two weeks ago on github doesn't work in the new version of MusicBee that came out yesterday, the plugin disappeared from the player's plugin list.
ThY
Anybody else with this problem ?
Are there other plugins not working anymore with MB 3.6 ?
Havokdan
I decided to delete the plugin settings in the Appdata folder and the plugin reappeared in the list of plugins. I have no idea why he disappeared.
Lani
This just stopped working for me. I even deleted it and reinstalled it and nothing.
  • Heal The World
Nothing to this effect has changed on the MusicBee side as far as I am aware.
This plugin communicates with a third-party - so perhaps something has changed on their side?
Strength and Honour (2025)
ThY
I gave it a try on MB 3.6.9065, and it's working for me.
But still i can't sync "loved" status.
Lani
Tried everything, disabled then enabled, uninstalled, even reset my token lol and still... nothing. Shame cause this worked pretty smoothly before.
ETA: Today, for some reason, it's working again? lol
Last Edit: January 08, 2025, 02:37:29 AM by Lani
