Author Topic: Now Playing panel config enhancements  (Read 28559 times)
i've fixed the GUI bug and a couple of other things with hidden lyrics.
in the end i decided on 'Mini Player (Compact Mode)' rather than causing confusion by renaming the existing mini-player to "bar player"
also for the mini-player it now has a musicbee icon.
if you click the icon (including with the main player and compact player), it will show a context menu that has common functions you might use)
fish, it was a bug that you were able to open 2 players at once and i have fixed that. For now, if you click on the musicbee icon you can switch to another player view. I havent rejected your suggestion but i dont know how to do it on the new windows 7 glass caption bar so it might be some time before i do it.
http://www.mediafire.com/?89swzgnvvtjuqnw
Last Edit: April 05, 2011, 10:26:11 PM by Steven
carloscs
Small bug:
Closed MusicBee with compact player showing. After restart, both the main window and the compact player window are shown.
when you close MB from the compact player it should re-open just the compact player, so was that just a once off or does it always do that? or is it under certain circumstances?
VX
Thanks, Steven  :) I like the changes introduced in MB 1.2.4112, especially the new name (despite being a bit too long) and adding the MB icon with common functions in Compact view  8)).
Small bug:
i haven't been able to reproduce but i made a change that hopefully will fix it:
http://www.mediafire.com/?d7zugld7lr4lajd
