Author Topic: Why are my iTunes playlists not correctly imported  (Read 4026 times)
The fact that you have that "iTunes Music Library" file indicates that you did use the export function from iTunes, whether it was manual or automatic.
Good luck.  You can feel free to post what you like, but don't do it for my sake as I've become disinterested.
You need to have "Share iTunes xml with other applications" enabled in the iTunes advanced preferences.
If you send me the "iTunes Music Library.xml" file which is located in Music\iTunes then i will have a quick look
sinanfantie
Oke, it seems that already had the "share Itunes XML file with other applications" option enabled.
I would gladly like to send you my XML file but I couldn't see an option to sent a file to you.
upload the file somewhere like dropbox or mediafire.com and pm me the link
Thanks for sending the file. Can you let me know an example playlist/ song that is wrong - I checked a random sample and they all looked ok
sinanfantie
The selected songs as seen in the screenshot should be placed in the playlist called "Chill Vibes".
https://imgur.com/iaqd5TE
In the second screenshot, you can see that the songs are indeed added to the playlist in Itunes.
https://imgur.com/KRju96I
It Ain't Me is one of the ones i checked and is in the Chill Vibes playlist.
Did you look in the playlist itself rather than depending on the playlist field?
I dont think i can help further as i am not seeing any issues with the import file
sinanfantie
sinanfantie
In Itunes, the song is in the playlist yes.
 But in Musicbee the song is not in the playlist.
Clearly its quite different as the playlist i have for Chill Vibes has 21 tracks. The only suggestion I have is perhaps you are using a different iTunes XML file to the one you sent me.
Perhaps try setting up a new library and then running the Library/ Import/ iTunes command; manually selecting the file you sent me using the Locate iTunes button
sinanfantie
I followed your steps and I made Step-by-Step screenshot so you can see how I did all of. So maybe if I am doing something wrong you can see/notice it.
https://imgur.com/JjQG2Ho
https://imgur.com/VZSEFEr
AFTER CREATING A NEW LIBRARY ALL MY SONGS SHOWED UP BY ITLSEF
https://imgur.com/fhBKiUW
https://imgur.com/kfVpleZ
https://imgur.com/undefined
sinanfantie
It seems that nobody cares about this problem. I planned on deleting MB because It doesn't sync well with my songs from Itunes
'Nobody cares'?
You've received a lot of swift replies and support from several people trying to help you.
I see you already left and deleted your account.
Good riddance.
Ungrateful sinanfantie. (probably some failed anagram for infantile)
