Author Topic: Why are some tags not displayed?  (Read 893 times)
wirtual82
I used Picard to download some tags, which cannot be displayed, for instance, original date/year. Is there a solution for that?
Last Edit: April 15, 2020, 12:49:59 PM by wirtual82
Some screenshots would be helpful. Have you looked at the tag inspector to verify if Picard actually inserted any tags.
wirtual82
Solved. I defined a tag code in the custom tags etc. The problem was that MB needed to re-scan the library to make them show etc.
Last Edit: April 22, 2020, 04:07:00 PM by wirtual82
Ok, glad it's fixed. There is a built-in original year tag, btw
