Author Topic: How to Play More than One Song?  (Read 2116 times)
HoldyourfireAl
If you have a CD inserted on your PC or you have a folder containing FLACS, you can't choose to Open With...MusicBee. So, I click on a track I want & they click Open with MusicBee. Unfortunately, MusicBee only plays that one track. How do I get it to keep playing all the tracks in the list or an entire CD for that matter?
Thanks!
Open a new tab by clicking the + button; Select Computer in the left navigator and then click on the DVD drive. The main panel will show the tracks on the CD and you can play them
It means selecting what you're going to play from within MusicBee rather than from Windows File Explorer will give the result you seek.
HoldyourfireAl
OK. I just did what you said. I clicked Play Now on Track 26. Let's see if it advances to Track 27 when done...
HoldyourfireAl
That worked! Thank you sooo much!
HoldyourfireAl
I'm noticing MusicBee skips songs when I do this. Is this a known issue?
