Author Topic: Podcast episodes changing to next episode prior to finishing  (Read 758 times)
Dangers_Dad_236
Hello,
The issue I'm having with my podcasts is that when I'm playing an episode it will skip to the next episode automatically before the episode I'm listening to has finished. I think it may be something to do with how the "Now Playing" pane is configured but I cannot find any settings that I think are related to this issue.
This doesn't happen when I download an episode, and I know the first reply will be "just download the episode". I wanted to see if there is a fix for this first.
Thank you for your help!
Paul
do you have any DSP plugins enabled or in the Player preferences, things like skip silence enabled?
Also how many seconds before the end of the track does it go to the next track?
EdWood
Same behavior as I described in this post: "Major problems with streaming podcasts - playback suddenly stops at random"
Can you let me know the subscription link for the feed and also which windows version you are using (there is a bug with the upcoming windows 10 release so i need to know if you use the standard release)
