Author Topic: Error switching from Theater Mode to Mini Player  (Read 1049 times)
carloscs
Steps to reproduce:
In main player press Ctrl-T (open theater), Ctrl-M (open Mini Player)
Sometimes only happens on the second round: Ctrl-T, Ctrl-M, Ctrl-M (go Main), Ctrl-T, Ctrl-M
MusicBee v3.3.7367.38620D  (Win10.0), 7 abr 2020 12:53:
System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'TheatrePanel'.
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Control.get_Handle()
   at System.Windows.Forms.Control.PointToScreen(Point p)
   at MusicBeePlugin.Plugin.TheatrePanel.FadeInPanel.parent_LocationChanged(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnLocationChanged(EventArgs e)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.OnLocationChanged(EventArgs #=zHB5no$s=)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds()
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=zSY5hHAbHQ4EHcR39WuTgwzM=.WndProc(Message& #=z9FSiH_o=)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.WndProc(Message& #=z9FSiH_o=)
could you send me a link to your settings file (help/ support/ view settings)
never mind about the settings file as i can reproduce it this time
edit:
this should fix the issue - its actually the theatremode plugin
Last Edit: April 08, 2020, 09:27:10 AM by Steven
