Author Topic: Issue - "the source file for track.. "  (Read 3687 times)
enigma1992
I have installed new version of windows. I saved MusicBee folders and after installing the windows I Copy-Paste the old folders on the new ones. Now, while trying to play songs in my MusicBee library, I am getting this message : "The source file for track "" could not be found". The problem is that when I click on "Locate in wondows explorer" nothing happens.
How can I fix it ?
Thanks.
You can probably solve this by using the "remap music file paths" command in the file menu. Look at the path musicbee thinks the tracks are at vs where they are now. At a guess, your username may be different. Anyway, put the old path and the new path into the remap tool and see if that solves it.
enigma1992
Ok, it worked. Thanks very much.
Last Edit: April 04, 2020, 09:53:46 AM by enigma1992
