Author Topic: Error when rating a track  (Read 855 times)
vidz97
17.03.2020 21:35:58 - 10.0.18363.0 - 3.3.7367.38620D - System.NullReferenceException: Object reference not set to an instance of an object.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at System.Windows.Forms.Control.Invoke(Delegate method)
   at #=zADbnadLxl1TKH02_Qzso3yQ4IyJJ.#=z8qGFd8A=(MethodInvoker #=zE7sPqAQ=)
   at #=z7Y36oGYLB7zzd9xX1w==.#=ztzLTs8GifjCy(Int32 #=zpysnetI=, Object #=zDt5M5b8=)
17.03.2020 21:36:07 - 10.0.18363.0 - 3.3.7367.38620D - System.NullReferenceException: Object reference not set to an instance of an object.
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zH6w$9kE=.#=zmI807nKDVUeRC1reKHl1b6Y=(String[][] #=zg6BFEgAPwPO3)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zizd53H1Kk$8e(IList`1 #=zwl3UI6s=, TagCode #=z1VUn09w=, Boolean #=z8LwBDv0bkZ7B)
   at #=zADbnadLxl1TKH02_Qzso3yQ4IyJJ.#=zbApRtH86SCzj(IList`1 #=zwl3UI6s=, TagCode #=z1VUn09w=, Boolean #=z8LwBDv0bkZ7B)
   at #=z1zm4aXqWrfM9o3M4EPnptYQ=.#=zusNHxwWtzi00.#=zDdOYJBho6Qzh(MouseEventArgs #=zHB5no$s=)
   at #=zCCTDpatEvC8oabAfkm14Kjo1vQtxPMhjN$KkcIM=.#=zmrkNOQuKM1cu7sdehxYEGD4=.#=zrfLRVUNINHNIQDx3f1siVA9BR5HM.#=zDdOYJBho6Qzh(MouseEventArgs #=zHB5no$s=)
   at #=z5awj1p0W8hR$QrJMq6MdV9c=.#=zmmVaT3pjS410.OnMouseDown(MouseEventArgs #=zHB5no$s=)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at #=z1b1aIHdE5iOu51l_1OHtZfM=.WndProc(Message& #=z9FSiH_o=)
vidz97
Reading through the forum I found the following post: https://getmusicbee.com/forum/index.php?topic=30985.0
I reverted to a backup settings file and solved this issue.
I have no idea how this happened, though.
Yes its the same issue as the linked post. If it happens again could you let me know
