Hello,
I'm new to the forum but have been using MusicBee for years now. Just want to add before reporting my bug that it's the best music software out there and it lets you handle your music library in amazing ways.
So my bug is not a big one. Whenever I create a playlist, analyse music, auto-tag by album and actions like these, I get this error (likely not always with the same random characters, but it's always in the same vein) :
MusicBee v3.3.7367.38620D (Win10.0), 12 Mar 2020 11:37:
at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zH6w$9kE=.#=zmI807nKDVUeRC1reKHl1b6Y=(String[][] #=zg6BFEgAPwPO3)
at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zizd53H1Kk$8e(IList`1 #=zwl3UI6s=, TagCode #=z1VUn09w=, Boolean #=z8LwBDv0bkZ7B)
at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=z7nUA$PMMuk7v(String #=zumsg5SI=, List`1 #=zvHGv1A$k5XdK, Boolean #=z3sxbwE4=)
at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zo3JS0rNL4vf$4b3cRQ==(String #=zcc8Jzz4=, List`1 #=zkvN9$m7QiXHD, Boolean #=z3sxbwE4=)
at #=zADbnadLxl1TKH02_Qzso3yQ4IyJJ.#=zbCbCmL8=.#=z8qGFd8A=(ApplicationCommand #=zYPDjVpU=, Object #=zV8gvbZE=, IList`1 #=zwl3UI6s=)
at #=z4EgwUhxpom0N1K03jT6eNkk=.OnClick(EventArgs #=zHB5no$s=)
It doesn't result in the cancellation of the action that has always been, until now, completed successfully. It just shows up at the end of it !
As the log shows I'm already running the latest version.
Thanks in advance and thanks again for all the great work.
