Author Topic: inbox and remove file  (Read 2808 times)
urfausto
why, if i set add new files to inbox, the message i get when i remove one file says "remove from library"?
The use of “library” in MusicBee is a little fuzzy. In this case, library refers to any files that have been scanned into your database, so including Inbox, Audiobooks, etc
urfausto
jeez, then how do you distinguish from library and inbox?
There's a "Mail" icon next to tracks in your inbox and a music note icon next to tracks in your library.
urfausto
nice, but i don't see this...  :( how do i set it?
They show when you do a search.
If you're looking at a playlist, right click the file and select "Send To." Whichever option is greyed-out is where the file is.
Where else are you having trouble determining which files are in the Inbox and which are in the library?  Everywhere else it's pretty self-explanatory (i.e. if you're looking at your library and you see the file, it's in the library / if you're looking at your inbox and you see the file, it's in the inbox).
You can also display the Category tag to see this.
I did not know this. Thanks.
urfausto
ok i've finally found the tabs for library and inbox. d'oh.
still don't know how to see those icons but ok...
Last Edit: February 29, 2020, 09:27:13 AM by urfausto
The icons show up if you're doing a search of your whole library.
urfausto
oh yeah i see this just now, in the search box you can change the search spectrum to the entire stored music
