Hello.
MusicBee is a really good app.
I used to convert mp3 with another app and then use mp3tag to get artwork, but I think MusicBee can do both.
However, when converting TAK + CUE to mp3, I want to output each track but convert it to include the next track.
I will list the steps that caused this bug.
1.Load TAK + CUE album into MusicBee and convert to mp3.
2.Here is the setting of the file converter I am using.
3.The track time of TAK + CUE and the track time of the converted mp3 are different. Of course, the track time of TAK + CUE is correct.
*TAK+CUE on MusicBee
*Converted mp3 files
4.I also put the settings of the file converter of Preference. lame is the latest one.
In the next version, I am glad that the track time is normal even with TAK + CUE.
I will be grateful if you have the information you need to investigate.
I'm not good at English, so please tell me if you don't understand anything.
thanks
*Postscript
When I converted from TAK + CUE to mp3 with foobar2000, the track time was no problem.
The version of the decoder of TAK is the same as that of MusicBee.
The lame is the same as the path set in MusicBee.
