Author Topic: Wrong time on songs  (Read 6424 times)
NailJ
Fixed!
Please let us know what worked so that others may benefit, thanks!
I sent the files to hiccup and he "removed the Xing header" and sent them back to me. I don't really know what that means, perhaps he can explain further
NailJ
I got my album fixed, hiccup got some great new music (if you like americana/ singer-songwriter that is lol), Win-Win  :)
Fixed!
... perhaps he can explain further ...
I removed the Xing header.
In MP3Diags that option is not available by default, through configuration you'll need to move it from 'Invisible transformations' to 'Visible transformations first.
If I understand correctly, while these headers are necessary for VBR files, they may be absent/removed for CBR files.
(if anyone has different information or experiences, please chip-in)
@NailJ: Be sure to keep your original files stored for a while in case the performed lobotomy has some negative effects. (I don't expect so, but you never know)
Thanks Hiccup and NailJ for the info!  Did you happen to try the Foobar "Fix VBR Header" tool suggested by frankz?
Last Edit: February 21, 2020, 07:57:42 PM by sveakul
I take it that the Foobar "Fix VBR Header" tool wasn't enough for this case?
I hadn't tried that, and I already deleted the original files so I can't try it now.
Perhaps NailJ can give that a try?
NailJ
Tried Foobar's 'Fix VBR Header' now (missed Frankz post for some reason, sorry...)
It didn't work, duration times are still off. It did change the numbers though, but not to the correct numbers (!?)
Skibear
Im so glad it all worked out for you! Here we are 6 months later and musicbee just as good as ever!
glad to hear you are enjoying musicbee
