Author Topic: FLUENT CAROUSEL. View your next 10 songs in perspective view.  (Read 14187 times)
mmakes
Had some fun with math and made this. This is great for people who listen to playlists or songs in random order.
Download the latest release here:
https://mmak.es/MetrologyFluentCarouselMB
Installation Instructions:
https://mmak.es/MetrologyforMBGuide
If you're using it, please post a screenshot of how it looks on your end! That'd be very helpful.
Last Edit: February 12, 2020, 09:45:03 AM by mmakes
I love it! Might have to try this out.
mmakes
Looks great - is there a link to try it out?
Oops I forgot to post the link. Just switched to hosting on Github:
https://mmak.es/FluentCarouselTMMBBETA
Btw, does anyone know how to hide the UP NEXT texts when I unhide the play buttons?
Last Edit: February 09, 2020, 02:25:31 AM by mmakes
In case you are not aware, you can also use "Albums[]" instead of "Tracks[]" for choosing which album cover to show. So if anyway is playing all tracks from an album, they would only see the album once vs. Tracks which works better with shuffle mode.
Also feel free to submit these skins to the addons page
Freddy Barker
  • 🎧 MB 3.4.7628P
Totally awesome, nice job, I would definitely use that!
I can imagine it looking great on a big TV.
Please post a link when you can.  ;D
Regards: Freddy
Mobbsypom
Unfortunately, I have no idea how to convert those lines of compelling numbers and symbols, into anything like the images!
I tried replacing the text in an existing xml document,but all that happened was my screen was filled with more compelling symbols and numbers!
Any help would greatly received..and I apologise in advance if it is blindingly obvious
thanks,
Mobbsy
It would avoid a lot of confusion if you posted a download link to the skin as an actual xml file, as opposed to the text CONTENT of the file, which would bypass issues such as how browsers render the GitHub content, copy/paste snafus, etc.  Thanks very much for your creation and for offering the results to others.
mmakes
Thanks to Freddy I managed to make player controls appear on mouseover, which is neat:
Also I updated all the links at the top to my Github. It makes more sense to host there rather than Google Drive.
pedromeneses
Is it possible to decrease the resolution of this "theater mode" by editing the corresponding XML file? if so, can you give an example of the field to be edited ?. My notebook has a 1366x768 resolution and when I use "theater fluent mode" there is a part below the screen that does not appear and that is why the play / pause buttons and skip do not appear (even in full screen)
