I do not think that is the issue because my resolution is set at the best setting as of now.
I'm sorry for any misunderstanding, how do you suggest I solve the problem?
Very awesome stuff! But I'm having a slight issue. It is not fitted into my screen properly, some of the buttons are partly outside the screen even if I double-click to enter fullscreen. It is only better when I go to theater panel dock and I change the startup mode to fullscreen.
