Author Topic: Auto-Playlist That Checks Genre and Path Folder  (Read 543 times)
ChristoMorse
Hello,
I think this might be an easy one, but I haven't been able to figure it out.
I want to create an Auto-Playlist than checks both the Genre tag and the Path of the file (songs are stored in Genre folders), and show all the songs where the folder and the actual tag do not match.
Have you guys tried something similar? What am I missing?
Thanks.
You'll need a virtual tags for this. There is a guide around somewhere for making a "folder" virtual tag, so you can isolate just the folder name. Then compared that to the genre tag and output Y or N depending on if there is a match.
You can make a playlist based on the value of that virtual tag.
