Author Topic: Compact Player Does Not Show Artwork  (Read 1561 times)
landmark
Something flipped in MusicBee, and now my compact player doesn't show album artwork. Here's a screenshot:
How can I get the artwork back?
If you open the tag editor for the file, is there artwork shown?
landmark
Yes, there's artwork in the editor and in the library.
can you send a link to your settings file (help/ support/ view settings)
landmark
Sure. How should I send the link? Do you have a way I could directly send it to you? Or should I upload it in Google Drive and post a link to the file?
landmark
I can reproduce the issue with your settings and this should fix the issue:
