Author Topic: Start Time - End Time-How to locate files/Modify or create rule in Auto-Playlist  (Read 682 times)
JamieC
I recently created a playlist for a specific party that would allow good song transitions without my intervention using a number of start time and end time settings.
This was only needed for that playlist.
So now...how do I create a view or a search so I can see all songs with either value configured different than default?
I've read this value is stored in the MB library.  Is there a reason this is not surfaced in the interface?
I don't think this is currently possible. You could make a wishlist request.
Practically speaking, see if you select all the files in that particular playlist whether you can mass edit the start and end times.
