Author Topic: How do I open mp4 files with external player like the other video formats?  (Read 4504 times)
jonap
Video formats like .avi, .wmv, .mkv open with external program chosen in setting
but mp4 act like music files and so get opened inside Musicbee (only audio)
is it possible to make mp4 act like video files?
Have you tried setting the association for mp4 in Windows itself?
(Settings > Choose default apps by file type)
jonap
yes, mp4 are regularly associated with vlc
Ah, sorry, I wasn't very focused here.
So you have those video files in your MusicBee library on purpose.
I don't use MB for video in any way, maybe some other user can chime in here?
Ah wait, I remembered something.
If you have your mp4 files under the audio node they will be handled as audio, but if you put them under the video node it should work as you want.
jonap
they are indeed in the video node, together with all the other video files with different format
but only mp4 don't open the external program
jonap
Ok, I thought perhaps you were using a 'Store' version. (which sometimes has it's own specific issues)
I'm sorry, I have no other ideas or suggestions.
jonap
So is it working normal for you?
I still didn't understand if it's a problem I have, or is it a normal behavior for mp4 files
Could you just try and see if it works for you, so that I understand if it's a problem or just not possible?
As mentioned before, I don't use MB for video files.
I can't test this today, but I can do it tomorrow.
But I am hoping some other forum member can chip in first.
Roby
Tried now: MusicBee regularly opens my .mp4 files with VLC ( (both latest portable version).
One more thing: all my audio files in Windows are not associated with MusicBee but with Foobar. I don't know if it's important ...
Last Edit: January 22, 2020, 10:27:07 AM by Roby
jonap
thanks, at least now I know it's my problem
my audio files are not associated with MusicBee either
Roby
But on my wife's pc, same configuration, MB plays the .mp4 files as audio files and does not open them inVLC. Very strange.
jonap
alright, so I guess I discovered the problem
I am used to put all my files in the monitored folders to go to the inbox, where I edit the tags and then send them to the library
So it's in the Inbox that mp4s are actually considered audio files (since Inbox is in common for all the files)
Then when I send them to the library under the Video node, it's all normal and they act like regular video files
