Author Topic: Toolbar buttons visual glitch  (Read 1133 times)
chrctrlmt
Hello,
I don't know what triggers it, but the toolbar at the top of the MB player (where all my custom buttons are) has a small white line above each toolbar button to visually indicate it.
The odd thing is, whenever I move/resize the window, they disappear.  Tbh, I don't even know why they're there in the first place, but I like them.  Hoping to find out what's making them disappear so I can keep them.
Screenshot attached.  It's hard to see, but there is a little white line above the text of each button.
Which skin is that or can you send me a link to the .xml or .xlmc file in the Skins folder
I would also need a link to your settings file (help/ support/ view settings)
Last Edit: January 12, 2020, 11:15:27 AM by Steven
I am not able to reproduce the issue with your settings. Can you confirm the DPI scaling you using (probably 100%)
chrctrlmt
I'm using a laptop, home PC and work PC, and I can confirm it's at least happening on both the PCs.  Sent via PM.  Is that what you are looking for?
