Author Topic: Updating MB?  (Read 1106 times)
jeestring
There's no way to update MB? We absolutely need to uninstall, download and reinstall newer version?
And will the settings save and skin work on the newer version? Do i need to re-do everything?
It depends on if you are updating from an extremely old version or not.  If you're updating anything from version 3.2 onwards, all you need to do is apply the "incremental update" (https://getmusicbee.com/forum/index.php?topic=27074.msg169188#msg169188).
Of course, it's smart practice to make a backup of your original setup first.  With the Portable version that's as easy as just copying the MusicBee folder you used elsewhere.
The "Windows Store" version cannot be manually updated, you have to wait for an auto-delivered update.
