Author Topic: Playlist folder not updating  (Read 1728 times)
dirtee
Hello!
I've been creating new playlists, but they do not appear in the "playlist" folder in my library.
Any help with that?
Also, is there any way to check if those mbp files are being updated?
Thanks!
How are you creating the new playlists?
dirtee
Hey Phred, thanks for answering!
Just in musicbee, right click, create new playlist.
And have you looked with a file explorer to see if the playlists are being created?
What version of MB? (help > about)
And is it the store version, installer, or portable?
dirtee
Hey man, MusicBee 3.3.7261 !
I searched with File Explorer as you suggested - good idea - and found them. They're in a separate part of my PC, the "Playlists" folder in my current library must be an outdated one then.
Any advice on how to move the actual current playlist folder then?
There was a bug. The latest update on the downloads page should work
dirtee
Hey Steven, thanks, downloaded the new version.
But that hasn't fixed it. I think the problem was linked to me re-installing MusicBee on new laptop and trying to get all my music back to where it's supposed to be.
How can I change the directory of the playlist folder?
(Where is it supposed to be by default? Within the library folder?)
dirtee
Also, has the new update stopped me from dragging files directly into the interface library..?
That could happen if you're running as sn administrator
dirtee
Hah, I had this problem a few months ago, and sorted it already with your help actually Psychoadept.
So something in the last week since I last dragged and dropped a folder has changed, and that's either the patch, or maybe installing AVG, could that have changed it?
Yeah, it could definitely be interference from an AV
dirtee
I seem to have fixed the drag issue through AVG.
But any help on relocating my playlist folder?
You can change your playlist directory in Library Preferences. You might want to look over preferences on the wiki, they're fairly well documented
