Hi, first of all I want to thank the developer to provide a so usefull and well made FREE software, said that I noticed the following issues:
1) The <bit depth> and <sample rate> tags stopped to work for my .dsf files (DSD), more precisely bit depth is completely missing while sample rate is 88.2 kHz while it should be 2.8 MHz, but the stangest thing is that for older albums the info is correct (1 bit / 2.8 MHz) while for newly added albums is wrong (missing / 88.2 kHz) so now in the library I have a mix of the two.
As another proof of the strange behaviour if I remove an album and then re-add it gets wrong attributes.
2) The HDCD doesn't work, I noticed that when I enable it and then playback an album there is no information showed in the footer so I don't know if it is working or not. Moreover if I exit the program and reopen the EQ panel HDCD.dll has no tick, each time I close the program it loses the selection.
Here some screenshots:
The current version of MusicBee I'm using is 3.3.7261 Portable
I thank you in advance for any usefull answer.
