Author Topic: No longer changing folder names  (Read 1845 times)
Alexander09138
MusicBee has always changed the folder name of an album when I change the album tag.
But as of a week ago (I didn't realize right away), any music I have previously added to my library, it will not update the folder name.
If I delete it from the library and add it back, then it changes it just fine (so the autosweep works).
Just not when it's already in my library. It's very annoying because none of my settings or setup has changed.
This has never happened before and I have no idea what to do. I tried re-scanning all files, changing the album name of various things, and it never updates the folder name. I was on the previous update, but after updating to the newest version this still persists
What am I supposed to do? I have thousands of tracks and hundreds of albums.
https://imgur.com/a/473L9IR
Last Edit: December 30, 2019, 12:43:13 AM by psychoadept
Hi, welcome to the forum!
According to your screenshot, you have two rules for C: and none for D:, so once a track is moved to D: it will not be moved/renamed again. Try changing one of the drive letters under "on drive" to D:.
Alexander09138
Ah, alright. I don't know how that happened. I changed the second one to move from disk D to D, and it renamed them properly. Thanks.
