Author Topic: Show all songs  (Read 4921 times)
pgalbraith
I'm surprised I couldn't find an answer to this anywhere!  Is there a way to get a simple list of all the songs in your library, like the iTunes songs view?  Or, barring that, can I get a list view of my highest rated songs?
Hi, welcome to the forum!
It sounds like you're looking for tracks view. Check out this page for information about changing main panel views: https://musicbee.fandom.com/wiki/Main_Panel_Views
pgalbraith
Thanks!!  The wiki page helps, but still doesn't give the full picture, to duplicate the iTunes songs list you need to:
1. from any tab, in the left hand column select "all albums" (at the top of the album list)
2. in the view pane to the right of the albums list, click the drop-down at the top of the view pane (NOT the drop down above the album list) and select "tracks" (as per the wiki page)
