Author Topic: pull tags by release id - vinyls  (Read 2315 times)
urfausto
There are releases which are not in mbz, so even picard is useless while Discogs doesn't show results possibly because it is a vinyl rip, is it possible to get new a feature to pull metadata by release id?
Last Edit: December 03, 2019, 11:17:43 AM by urfausto
You can always add releases to MusicBrainz. What release id are you referring to?
urfausto
https://www.discogs.com/it/it/release/7494519
in this set for example there are 5 folders for 5 media supports but the release is one, i don't know how it works with discogs..
adanteh
Some raw ID field would be pretty nice in the Auto-Tagger, some random example I stumbled onto that didnt want to be found is
https://www.discogs.com/release/9568426
