Author Topic: Second Rating in Main-Panel  (Read 999 times)
MC_K3NNA
I made a secondary rating via embedded custom-tags (called "Intensity").
Why cant i edit the custom rating from the main-panel like the regular rating
and have to go for the "edit" Window?
thx!
  • MB Version: 3.6.8878 P
You probably need to 'enable direct editing of tags in the main panel'
Preferences> Tags(2)> tag handling
MC_K3NNA
Hi!
Thx for your answare!
I didn't knew about that option. But its already checked.
It's about to be able to set the rating with mouse-over effect of the stars.
Regular rating tag is working that way - my custom-tag doesn't.
So any other ideas?
Last Edit: November 26, 2019, 03:36:32 PM by MC_K3NNA
It's probably more complicated to implement for a custom tag. It's fairly recent to even support rating view for a custom tag
alec.tron
Neat.
+1 for "mouse-over effect" on a custom tag in "rating view", plus the ability to assign custom shapes/images/ico files for the representation of such so we can use other than the standard star.
That would be grand.
Churs.
c.
