Author Topic: Adjust the virtual tag  (Read 1191 times)
Sofocl
Help to Adjust so that the album is not displayed if the first rule is executed;
$If($Contains(<Title>,": ")="F",,$Split(<Title>,": ",1)) $IsNull(<Title>,<Album>,<Album>)
Sorry for my bad English.
smann
Helps to explain in detail exactly what you are trying to achieve. I can't quite follow what you're looking for from that tag.
If I understand what you're asking for, try this:
$If($Contains(<Title>,": ")="F",$IsNull(<Title>,<Album>,<Album>),$Split(<Title>,": ",1))
Then if title is not null AND does not contain ":" the album will be displayed.
  • MB Version: 3.6.8878 P
I find if you work from what you least want to what you most want in the virtual tag, you end up with the shortest expression:
$IsNull(<Title>,<Album>,$If($Contains(<Title>,": ")="T",$Split(<Title>,": ",1),<Title>))
Sofocl
Great. Thank you all! Option psychoadept the that need to.
Now for classic albums it looks like this:
And for the rest so:
