Author Topic: For hours MusicBee consumes 20 - 35 & CPU  (Read 2190 times)
stardepp
I have a new desktop PC since one week, technical data here:
I Use MusicBee 3.3.7252
What could be the reason and how can I achieve that MusicBee uses significantly less CPU?
In the MusicBee folder
C:\Users\stgru\AppData\Local\MusicBee\InternalCache
I cleared the cache and then restarted MusicBee, but that didn't help.
What anti-virus are you using? I wonder if there's something interfering with file access.
stardepp
I use Windows Defender on my Windows 10.
My desktop is brand new, a week ago I put it into operation for the first time.
I had ADWCleaner searched, but he found nothing suspicious.
Last Edit: November 11, 2019, 07:57:41 PM by stardepp
Huh. I also use Windows defender, and mb typically uses .5-1% for playing music.
As well as the above, i suggest you do a brand new portable install with no plugins installed and see if it still happens.
Ok, but how do I install MusicBee Portable and in which Windows folder?
https://getmusicbee.com/downloads/
Download the portable version, and install it in a folder outside one of Windows' essential OS folders.
Put it on another partition (drive letter) if available.
A partition on an ssd is much preferred over hdd.
stardepp
I really appreciate your help.
I used a third software as task manager, uninstalled it and instead used the standard Windows task manager and here both MusicBee (MusicBee normal and MusicBee Portable) normally move between 1 and 4% CPU.
What's the name of the now removed task manager?
stardepp
This is simply called "System Explorer"
http://systemexplorer.net/
Surely System Explorer did not work properly anymore, because this software was last updated on 22.04.2016.
Last Edit: November 12, 2019, 12:07:34 PM by stardepp
Thanks. Based on your experience with it I wasn't planning on using it. I wanted to check the name to make sure I didn't have it in my archives of Task Managers. I did, but I deleted it.
