Author Topic: Help regarding MusicBee on iPhone  (Read 1745 times)
Morghini456
Hi, I'm fairly new to MusicBee as I saved the Xenoblade 1 album and Smash albums together in MusicBee. I want to listen to them MusicBee albums I saved from my laptop onto my iPhone. I really don't know how to do it, so if anyone can help me, then that'd be fairly appreciated.
Hi, welcome to the forum!
I suggest you take a look at this thread: https://getmusicbee.com/forum/index.php?topic=20635.0
Morghini456
I had a look at the link, and does it work for iOS 13.2, pscyhoadept?
Last Edit: November 01, 2019, 02:01:39 PM by Morghini456
Morghini456
Also, I'm meant to download the folder onto my computer right?
If you're asking about the plugin, you should post in the plugin's thread.
Note that the plugin psychoadept referenced is no longer supported. And a note on the plugin page states that it was tested with itunes 9 and "...probably won't work with higher versions..."
Morghini456
Phred, I unzipped the patched folder but I don't know what to do now.
Read the plugin's thread and post your questions there.
I'm locking this thread because the questions you're asking, and the possible answers to them, belong on the plugin's thread. Continuing discussion here will only lead to multiple threads for the plugin.
