Author Topic: Change all the featuring artists to the title  (Read 1269 times)
tverderesi
Hello, I use musicbee with a fairly large library (around 90000 songs) and I use an android phone to listen on the go. When I use the mobile player, it doesn't recognize the Album Artist field I sorted in Musicbee. Is there a script or a scripting tool I can use to change that? For example: I have Off the Grid by !!!., Meah Pace. Could I change it to Off the Grid (feat. Meah Pace) by !!! via a tool?
I -think- this has more to do with the player you're using on the device. If MB is syncing what you're telling it to, and the device isn't showing it, then it's probably the device.
What player app are you using? Have you tried with another app? I use GoneMad and don't see any such issue.
It sounds like the app might be showing you individual artist tags rather than the album artist. Have you tried selecting the option to sync display artist instead of artist?
