OK, I parsed the topic dealing with this issue: "Validation failed after attempting to save the file - the changes have not been saved." for months, with no real answer.
I tried almost anything, including permissions rights, without any luck.
Finally could dig deeper into the issue and here is my conclusion:
m4a/aac files created with mp4creator codec v1.4.15 are not supported in musicBee tool.
It makes them invalid in the library, in the sense that I cannot edit any tag. So they usually appear with no artist/album info, although the title seems to be Ok.
Since I create playlists based on tags, these files can never be added to my playlists at all, nor sync with my Android device.
Questions:
- Can we imagine a kind of plugin that would make these files valid in musicBee, in terms of tag changes? The files are correctly handled with mp3Tag v2.98 tool for example...
- What tool could I use to recode the tag used in these files to make them valid for musicBee? Is there a way without reencoding them, and losing quality into another aac format?
Thank you for your suggestions!
Bill
