Hi Steven,
I disabled the wavebar, re-started MB (just to be sure), and MB crashed same as before (good thing I like this song :-))
11/5/2019 1:12:41 PM - init chans=2
11/5/2019 1:12:42 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:42 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:12:43 PM - init=-2147483641,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:43 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:12:43 PM - init=-2147483640,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:45 PM - close stream=False
11/5/2019 1:12:45 PM - close stream handle=0
11/5/2019 1:13:28 PM - E:\Frank's Music\:Thread was being aborted.
11/5/2019 1:13:28 PM - close stream=False
11/5/2019 1:13:28 PM - close stream handle=0
11/5/2019 1:13:28 PM - Stop1=True
11/5/2019 1:13:28 PM - stop 0
11/5/2019 1:13:28 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 1:13:28 PM - assign channel paused
11/5/2019 1:13:28 PM - stop: before=False
11/5/2019 1:13:28 PM - stop done
11/5/2019 1:13:29 PM - dispose
11/5/2019 1:13:29 PM - stop: before=False
11/5/2019 1:13:29 PM - reset channels=0
11/5/2019 1:13:29 PM - reset channels done
11/5/2019 1:13:35 PM - init chans=2
11/5/2019 1:13:36 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:13:36 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:13:49 PM - close stream=False
11/5/2019 1:13:49 PM - close stream handle=0
11/5/2019 1:13:49 PM - Stop1=True
11/5/2019 1:13:49 PM - stop 0
11/5/2019 1:13:49 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 1:13:49 PM - assign channel paused
11/5/2019 1:13:49 PM - stop: before=False
11/5/2019 1:13:49 PM - stop done
11/5/2019 1:13:50 PM - init=-2147483641,source rate=5644800, remove silence=False,is tempo=False
11/5/2019 1:13:50 PM - set raw streaming=False,current mode=DOP
11/5/2019 1:13:50 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 1:13:50 PM - play=False,output=0,stream in mixer=False
11/5/2019 1:13:50 PM - play is paused=True
11/5/2019 1:13:50 PM - assign channel before=0,after=-2147483641,mode=DOP,started=False
11/5/2019 1:13:50 PM - assign channel:: chans=2,2; freq=352800,0
11/5/2019 1:13:50 PM - assign channel set format and rate
11/5/2019 1:13:50 PM - assign channel undo pause
11/5/2019 1:13:50 PM - assign channel done
11/5/2019 1:13:50 PM - play startedTrue
11/5/2019 1:16:51 PM - init=-2147483638,source rate=2822400, remove silence=False,is tempo=False
11/5/2019 1:16:51 PM - set raw streaming=False,current mode=DOP
11/5/2019 1:16:54 PM - remove eos 2=-2147483641
11/5/2019 1:16:54 PM - remove eos done
11/5/2019 1:16:54 PM - close stream=False
11/5/2019 1:16:54 PM - close stream handle=0
11/5/2019 1:16:54 PM - is same settings:: chans=2,2; freq=176400,352800
11/5/2019 1:16:54 PM - Reset5
11/5/2019 1:16:54 PM - reset -2147483641
11/5/2019 1:16:54 PM - assign channel before=-2147483641,after=0,mode=DOP,started=True
11/5/2019 1:16:54 PM - assign channel paused
11/5/2019 1:16:54 PM - reset done
11/5/2019 1:16:54 PM - free -2147483641
11/5/2019 1:16:54 PM - free done
11/5/2019 1:16:54 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 1:16:54 PM - play=False,output=0,stream in mixer=False
11/5/2019 1:16:54 PM - play is paused=True
11/5/2019 1:16:54 PM - assign channel before=0,after=-2147483638,mode=DOP,started=True
11/5/2019 1:16:54 PM - assign channel:: chans=2,2; freq=176400,352800
11/5/2019 1:17:47 PM - init chans=2
11/5/2019 1:17:48 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:17:48 PM - set raw streaming=False,current mode=PCM
