Author Topic: tabs bar below  (Read 1799 times)
stardepp
If you place the main player control at the bottom, it would also be good if you could place the table bar at the bottom as well.
Last Edit: October 09, 2019, 01:02:50 PM by stardepp
Perhaps it's a translation issue, but I have no idea what you're referring to. There is no element called the "table bar."
A screenshot would be most helpful.
I meant: Is it possible to move the tabs bar down?
Ahhh... -tab-bar, not the -table-bar.
No, it can't be moved to the bottom. But you can move it above or below the caption bar.
Click the square box to the left of the search bar > tabs bar > show below [or in] the caption bar.
