Author Topic: Tracks in Two Columns in Album Covers Mode  (Read 2262 times)
natkingcole
I recently transfered my music library from a desktop to a laptop, so I had to reconfigure my MusicBee. Pretty much everything is set up how I want it to be, but how would I go about making tracklists two columns instead of one?
It seems as though it should fit, no?
If making it wider doesn't help, make sure you don't have "display tracks as a single column list" selected under Customise Panel settings
DiscgraBee
Is there a way to make sub-headers override the columns to stop them cutting off?
Not using 'Display as single column list' looks very ugly:
Been trying to work this our for months!
I don't think there is a setting for that, it's probably by design.
I agree it would be better if the header and the subheader would not get cut-off in that situation.
It would probably be best to (re)post this as a wish.
(or, if psychoadept agrees that this is currently not possible, perhaps he can move this whole thread to the wish board)
Its an oversight - i think it would only really be an issue when "display single column" is ticked. It should be trivial to change so i will update the v3.3 patch version
edit:
Last Edit: October 10, 2019, 05:57:18 PM by Steven
DiscgraBee
Steven,
Thank you so much, I can't begin to tell you how much this update means. I very much appreciate it =)
