Author Topic: Wifi Sync - Invalid Filename error for all playlists  (Read 1370 times)
bartca89
When I attempt wifi sync to my Android device, I get the following error --- java.io.invalidobjectexception: Invalid filename --- I get this error for every one of my playlists, so none of them get copied. I've tried changing the playlist file type but it makes no difference. Any ideas?
Have you done a wired sync first? Steven has stated that before a wifi sync can be done, a wired sync (or preview) should be performed.
bartca89
Yes, I had to do a wired sync because it's the only thing I can get to work. I'm still getting the same error on wifi.
SkyZippr
This may not apply, but I had the same error when one of my songs contained an emoji in its file name.
