Author Topic: File Menu inaccessible  (Read 973 times)
leachs24
I get this error when I try to click Musicbee -> File.  I cannot click into the file menu.
MusicBee v3.3.7165.34284 (Win10.0), 15 Sep 2019 18:34:
   at #=zSARim0YRaXzbWnTvMJiZOZQ=.#=zcibU6B0YtmqGRj9P5A==(Boolean #=zr3s3RCkglUrM)
   at #=zxSs8$Zj1YyE$QLYKTW9wh8Od34QB.#=zd$DPQbCqigKf.#=zLrLM39s_s2nelAR90pmWKDQ=(Object #=zySAfqQw=, EventArgs #=z2hFhQMw=)
   at System.Windows.Forms.ToolStripDropDownItem.OnDropDownShow(EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnDropDownShow(EventArgs e)
   at System.Windows.Forms.ToolStripDropDownItem.ShowDropDownInternal()
   at System.Windows.Forms.ToolStripDropDownItem.ShowDropDown(Boolean mousePush)
   at System.Windows.Forms.ToolStripMenuItem.OnMenuAutoExpand()
   at System.Windows.Forms.MenuTimer.OnTick(Object sender, EventArgs e)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
does this version make any difference?
if it still happens, can you send me a link to your settings file (help/ support/ view settings)
leachs24
So I can access the file menu, but now when I try to scan for files, the number of files that I am trying to add shows up, but I am getting a File Scan Failed, and the files do not get added.  Here is a link to my file settings:  https://drive.google.com/open?id=1JklKVI2ANuVqwpZL7LGWpHEj2MtlCecg
Thanks!
It appears you have upgraded from a very old MB version (<= v2.5?) and that caused the original issue and still is causing issues elsewhere.
This should fix the upgrade issue but I cant say with certainty whether its related to the new issue you report
