Author Topic: <Lyrics?> not saved in Version: 3.3.7194 P  (Read 2199 times)
  • MB Version: 3.6.9255 P
Just updated from MB Version: 3.3.7169 P to Version: 3.3.7194 P and noticed this.
When lyrics are saved, <Lyrics?> no longer registers the change for "Y [unsynched]" or "Y [synched]".
Strangely though, if I mark a track as having no lyrics, <Lyrics?>  does change to "N [no lyrics]".
My lyrics are stored as external files.
this should fix the issue but i can only see it happening when saved in the lyrics panel for external files. If it was happening elsewhere can you let me know
Yep. All fixed with 3.3.7196 P. Thank you.
Forgot to mention that was the panel I was using in original report. Sorry  :-[
