Author Topic: Can I only see the tracks with no replay gain?  (Read 1434 times)
arbor_mute
I want to sort out the tracks without replay gain.
But it seems that smart playlist doesn't have feature to detect whether a file has replay gain or not.
Is there any smart way that I can only see the tracks with no replay gain?
Or, is there any way that I can make MB to skip the replay gain calculation if the file already has the replay gain?
Thanks
Last Edit: August 23, 2019, 09:30:28 PM by arbor_mute
In your library window right-click the header bar and choose "set displayed fields";  in the "Other" column you'll find both Album Gain and Track Gain.  Once displayed you can then sort by them to group files together that have the tags.  I'm sure there's other ways to do it but that's one way.
As far as auto-skipping calculation for files with pre-existing gain tags, I don't know if that's possible.
arbor_mute
You are my man! Thank you for your help  :-*  :-*  :-*  :-*  :-*
Here's another:
If you select tracks to analyze, tracks that already have a value should have an empty selection box and they won't be recalculated/rewritten.
You'll have to check/select them to recalculate/write new values.
