Author Topic: Library Reports - Strange Output - Musicbee version  (Read 1690 times)
ParaGnosis
Hey folks, first time posting here so please excuse me if I make any post errors. I also apologise because I can't find which version of Musicbee I'm running - (I started using it within the last 6 months if that helps.)
I am having some issues using the Musicbee Library Reports function.
I can't remember whether this is built into Musicbee or whether it's a Plugin I am using so I apologise for that.
Whenever I try to use the Library Reports I keep getting weird, "useless" data in my output.
The output inputs things like ALL TAGS 'ALBUM ARTIST (DISPLAYED)' at random intervals throughout each column, for no apparent reason, and without any logic I can find.
EDITED: The original picture would not load.
You can see this below...
Anyone got any ideas?
Thanks in advance!
Fiona
Last Edit: August 22, 2019, 04:10:56 PM by ParaGnosis
Version number is available at Help > About.
From your screenshot it looks like you're using the Additional Tagging & Reporting Tools plugin. If that's the case I will move this to the plugin's thread so that the plugin author can see it and respond. I don't have access to MB currently so I can't tell if you're using the plugin or not.
ParaGnosis
Hi phred, you are correct. I am using the Additional Tagging & Reporting Tools plugin. Please go ahead and move this query to the correct part of the forum.  :)
Thanks a lot!
ParaGnosis
@boroda Thanks so much for this! It's solved my issues completely! :D
