Author Topic: [Layout] Ability to show Artist column from top to bottom of the window  (Read 3848 times)
Patearson
Like is it possible in Itunes :p
With a pretty big library, I find the possibility of having a huge artist colum so much comfortable  ;D
have you considered using the library explorer in the left panel? it can be configured to only show artist
Patearson
 :o
Damn, I was sure that i'd looked everywhere  :-X
This is almost perfect, but it is a bit weird to have the infos there, then again in the track browser..
I think that adding the posibility to show such a layout wouldn't be so complicated, is it ?  :-*
yes i am planning to add this configuration to the "quick layout" choices.
Also, you can hide the track browser if you want or choose something other than artist in the browser column
Patearson
Great, thanks a lot !
Also, thank you so much for the work you'r doing, musicbee is the awesomest windows player ever !  :-*
