Author Topic: iPod 2 way synchronisation  (Read 1925 times)
Maith
https://imgur.com/Z3y9KbJ
Hey, since one of the latest updates, MusicBee does not support 2 way synchronization anymore. The field is not checkable anymore
Now I can't sync play counts. Is there a reason for this?
Can someone help out?
I'm using version 3.3.7115
I'm pretty sure MB -never- supported two way sync with iDevices. But you're implying that it did work for you previously. With what version?
My guess if it was working before, you were lucky and I doubt Steven is going to put any time into iDevice support. You can wait until Steven jumps in here, but I think you may be stuck with your previous version.
Maith
It worked like a charm in 3.2.6902
The fields also showed up
https://imgur.com/dok1K1f
Old iDevices with an old software installed by an old iTunes have always worked for me
The new version just seems to be missing those fields in the UI
Last Edit: July 31, 2019, 10:03:05 PM by Maith
Yes, that was the case a good number of years ago when I had a classic. But it just couldn't hold enough of my music. So I left the Dark Side and now work only with Androids.
I guess you're going to have for Steven to offer up a comment about this. Or leave the Dark Side.
